SDS100/SDS200: Help with Uniden settings
Bonkk083
Union, SC
I noticed some settings but don't know what they mean and do and read the easier to read manual
1. Set C-Ch output
2. P25 one frequency
3. Pre-emptive priority and how to enable it
Mikejo
Waltham,MA
Yeah, the manuals stink in that are great for showing you how to drill down to an item to enable or disable it, but they expect you to know exactly what they are and what they do… If they really want to be helpful, perhaps they could give a description of what these things actually four, and and are designed to do!
I’ve noticed that older manuals actually do a little bit of explaining about the features; the new manuals… Not so much!
dkcorlfla
Orlando
1. Set C-Ch output
Looks like you have a few Uniden scanners, I just took one and ran a search using "Set C-Ch output bcd886p2" without the quotes and stuff did pop up so maybe try that with the scanner you are tying to setup.
It really is amazing what one can find by using error or words from something you want to study and combine them with the device.
Hope this helps
dmfalk
Bonkk083
Union, SC
Would you be able to use the P25 one frequency for a trunked system that's digital
Whiskey3JMC
Airwave surfer...Cowabunga!
Philly burbs 🇺🇸
No. P25 Trunked systems encompass more than one frequency so program accordingly depending on the system in question "P25 Trunk" for Phase-I or "P25 X2-TDMA" for Phase-II or better yet, let Sentinel, Proscan or your programming app of choice do it for you
K9KLC
Southwest, IL
Also, get yourself a better antenna! My SDS100 with a Comet W100RX picks up all three regional NWS stations where I am, with the furthest about 90 miles away, and does it better than any radio (including dedicated weather radios) I've ever had.
Did you have your Comet W100 RX on the weather radios when you did this test?
dmfalk
Unfortunately, no, as they were non-removable. A shame, too, as one, a Midland, is a major weather radio manufacturer, and it's performance was quite dismal (of the three stations, only one clearly, the second marginal, and the third, the one 90 miles away, barely even readable).
But WITH the antenna, I could compare the HomePatrol 2 and the SDS100. The first two great, but the third was weak, but certainly more readable on the HP-2, but on the SDS100, all three come in strong!
For understanding how far, I'm in Eureka, CA, with the three NOAA Weather Radio stations being in Eureka, Willow Creek (30 miles away) and Brookings, OR (90 miles away).
K9KLC
Southwest, IL
ok thanks. I appreciate it.
Bonkk083
Union, SC
If you put the filter off in the settings and system settings to see what it would do should they 5 bars showing I turned it off but it showed no bars I'm not sure if that was right are not
Ubbe
Stockholm, Sweden
Signal strength in SDS scanners are measured not only from the frequency you are monitoring but can also come from transmitter frequencies many MHz away. Only reliable method are to check for lowest amount of bit errors from digital signals.
Filter settings are using a bandpass filter that are 10MHz wide.
Off are letting the signal pass in the middle of the filters bandwidth.
Normal are passing the signal near the edge of the filters frequency range.
Invert are using the other edge of the filter.
Wide are passing the received signal halfway to the edge of the filter.
The theory are that when you have an interfering signal 2MHz higher in frequency you then select a filter type that makes that signal be outside of the filters frequency range and do not let it pass thru it. But if you also had a strong signal 5MHz in the other direction it would pass thru the filter if using Normal or Invert and then the Wide setting could be used to have both signals end up outside of the filters frequency range.
If you get a lower signal strength when changing filters it could mean that you have managed to block an interfering signal. But if an interfering signal are way too strong it could also mean that you opened up the filter to that strong signal so it de-sense the receiver and you loose receiver sensitivity and the signal you are trying to monitor.
It will be almost impossible to know what are actually happening when only going by signal strength.
/Ubbe
Bonkk083
Union, SC
I have two questions
1. Can the UID be turned off on the SDS 200 like you can with the BCD996XT and P2.
2. What does the True I/Q do
mc48
Monroe County, NY
Yes, Unit ID is customizable in the display settings.
  • TRUE IQ RECEIVER
    Designed to improve digital performance, the TRUE I/Q Receiver captures the complete signal waveform in 3 dimensions, allowing for improved digital error correction and signal recovery.
Bonkk083
Union, SC
When you use the UID can you get for a different county on your local site thats on the same system
