Help
chrish04
San Antonio TX
TTID + # Usage
ID+0 Normal Talkgroup
ID+1 All Talkgroup
ID+2 Emergency
ID+3 talkgroup patch to another
ID+4 Emergency Patch
ID+5 Emergency multi-group
ID+6 Not assigned
ID+7 Multi-select (initiated by dispatcher)
ID+8 DES Encryption talkgroup
ID+9 DES All Talkgroup
ID+10 DES Emergency
ID+11 DES Talkgroup patch
ID+12 DES Emergency Patch
ID+13 DES Emergency multi-group
ID+14 Not assigned
ID+15 Multi-select DES TG
I got this of a section of the website but dont quite understand it. Does it mean i could program the talk groups then but that at the end
Ex
1616 Normal Talk group 161610 with emerg?
Any Help woud be nice.
Thanks,
Chris
W4KRR
Coconut Creek
1616 = normal talkgroup.
1616 + 10 = 1626, in your example.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
If you are creating scan lists then you will have to enter that "combined"
TG (e.g. 1626) in your lists for SCAN mode.
However, if you are in SEARCH mode and your status bit is off
then that and any "special" ID's should pop up.
Whichever way suits your monitoring habits.
BTW, Jay answers this same issue excellently in the Trunking
Forum
