HELP!!!!
LEH
Yorktown, Virginia
I'm using Win10 and it worked without any special software. Can't say for XP....
When you install the PPS software, make sure the radio IS NOT connected to the computer. This is a been there done that lesson.
The driver to connect did not install while the radio was connected. I had to disconnect, uninstall, reinstall, and then it all started working. This was with a Windoze 10 machine. Even in XP drivers do not install if the unit to be driven is connected. Simple Windoze rule that I forgot. :(
jpm
No that did not happen as I downloaded the updated software and the radio was not connected. I have programmed these systems three times, original, reprogrammed and reprogrammed again. Now some of the Lake county talkgroups come in once in awhile. Triple checked settings all three times. The first time I programmed the speaker icon with the x and I had to push the top button on the side to hear the transmissions. I did find out that one has to be on duty for the icon not to show with the x.Will try to program again and put it in another zone. Again thanks all for the help.
jpm
Unication Dave help
Recently purchased a G4 programming went well with some good results. The problem I'm having is on our STARCOM 21 trunked system. I am monitoring towers 115 Lake county and 146 McHenry county. The McHenry talk groups will pick up on the G4 at times. Uniden scanner picks up the talk groups that are silent on the McHenry talk groups. I have reprogrammed from scratch several times and the same result. Double and triple check all settings and still same result. Everything else programmed picks up transmissions. HELP!!! Thanks.
jpm
Firmware currently displaying Vo.93-0.171-R00, which I assume is the most updated.
troymail
Silent Key
Lake County is showing lots of "T" (P25 Phase 2) potential that the G4 won't receive (but the Uniden will). Could that be the problem?
McHenry doesn't show "T" but that doesn't necessarily mean they aren't using Phase 2....(dunno, I'm not there).
What is the Uniden displaying when it receives the talkgroups in question (that the G4 is not)? P25? PT0, PT1?
Note: I'm also betting that even those talkgroups marked "DE" (digital encrypted) are really supposed to be "TE" (digital PHASE 2 encrypted) - not that it matters too much given they are encrypted....
L
Legend2010
Guest
The system is Phase II. Your Uniden is most likely picking up PII and the G4 is only picking up PI.
jmontes77029
Baytown, Tx
P25 is phase 1 or 2. There are also some sites that carry phase 1 and 2 traffic as I found out where I live.
troymail
Silent Key
Sorry to hear you are having issues. David has been pretty low key almost absent since before the holidays.
If what we've provided (and asking to help confirm the issue - which David would need also) won't help you, I can only recommend that you might want to contact the vendor from which you purchased your radio for assistance.
jmontes77029
Baytown, Tx
I seem to not want help with all the name calling. Why not go to your states forum on here to try and get answers since we are idiots
jmontes77029
Baytown, Tx
Calm down and take a deep breath. I think you are not getting the answers you want to hear but what we have told you is what it is. The only reason you are picking up a talk group on your other radio and not the g4 is either you programmed the g4 wrong or the particular talk group is phase 2. Please provide the talkgroup that is only being heard on your other radio and not the g4. That may help narrow it down.
