OP25 Here we go again.
MCWKen
Clinton, IA
I was forced to rebuild the computer, and when it came to OP25, initially got many errors which I was able to solve. But this remains something I cannot resolve.
Error:
python version detected: 3.12.3 (main, Nov 6 2025, 13:44:16) [GCC 13.3.0]
main: exception occurred
main: exception:
Traceback (most recent call last):
File "/home/ken/op25/op25/gr-op25_repeater/apps/./rx.py", line 1030, in run
self.tb.start()
File "/usr/lib/python3/dist-packages/gnuradio/gr/top_block.py", line 116, in start
top_block_start_unlocked(self._impl, max_noutput_items)
RuntimeError: list contains invalid format!
Running Ubuntu 24.04.3
GNU Radio 3.10.12.3
Latest Boatbod package.
Command line:
/rx.py --args 'rtl' --gains 'lna:49' -S 2560000 -f 774.33125e6 -T trunkmusc.tsv -x -2 -n -2 -V -w 2> stderr.2
Any suggestions?
Thanks in advance,
Ken
  • stderr.2 12-15-25.txt
boatbod
Talbot Co, MD
Did you start with a fresh op25 install or copy the directories over from the old installation?
Best guess is there are remnants of an old build hanging around, either directly in the ~/op25 hierarchy or somewhere in /usr/local/lib where the shared libraries get installed. Recommend you blow it away and start over by running the ~/op25/install.sh script.
sean_
las vegas, nevada
I see this:
Code:
Can you post your trunkmusc.tsv or run without it?
MCWKen
Clinton, IA
I see this:
Code:
Tried to run:
ken@ken:~$ ./rx.py --args 'rtl' -f 774.3301250e6 2> stderr.2
Same error.
Ken
boatbod
Talbot Co, MD
If you google for "RuntimeError: list contains invalid format!" there are numerous hits for occurrences of this particular gnuradio error after some sort of update. Some mention gr-osmosdr, but either way I think it's a incompatibility between libraries - either those that you built yourself via the op25 install process or those that came in a package or were left behind from a previous install.
I do not think this has anything to do with op25 config file contents or format. Those typically produce other python errors.
MCWKen
Clinton, IA
I will follow the Google RuntimeError. Thanks
wgbecks
NE Wisconsin
Ken,
Were you able to get op25 going again? If not, send me a PM and I will be willing to assist offline.
Bill
