Hey Altec or Pappy 1
wrr20891
Do either of you know which frequency the State Highway Department uses in Garland and Hot Spring Counties? I heard AHTD in Saline County last night on 151.070, but not sure which frequency they use in Garland and Hot Spring Co.
Thanks.
pappy1
Central Arkansas
OK, here ya" go: Hot Spring, Garland, Saline, Pulaski, Prairie and Lonoak Counties is Distict 6 151.07 CT 107.2. Is this the info you were looking for?
Pappy
wrr20891
Yes, I guess I just heard Saline and didn't listen long enough for any trucks in Garland or Hot Spring.
Thanks Pappy.
btritch
Paragould/Greene County AR
Isn't AHTD also Using the AWIN system? I've not heard them on it but I have heard people talking of hearing them and they do have an id listed. Can anyone confirm?
wrr20891
Always listen to Pappy. :)
The Highway Department doesn't even have a channel on the ASUG template, just the Highway Police. I've never seen an 800 MHz antenna on a Highway Truck either, just a VHF whip.
pappy1
Central Arkansas
This TGID 3217 is listed in the database as AHTD talkgroop, it is a Highway Police TGID. You will find it is also listed in the Arkansas Highway Police Talkgroups listing.
altec
34° 36' 51.8" N, 92° 29' 54.3" W
Frequencies
Hey wrr20891, Once in a while I listen in on State Highway Departments frequencies. Most of the time its hardly active and when it is its mostly about signs being down or debris being on the highway. Now in winter time during snow/ice it picks up a bit. The highway police use these frequencies too but here lately have not due to the AWIN system. They have district maps and I think the State Highway Department is district 6 and the highway police are district 1.
Here is what I have gathered for the following frequencies.
151.010-131.8 PL Too much static and could not pick up what locations they were at.
151.055-114.8 PL Mostly around Clark, Montgomery, and Pike county areas.
151.055-141.3 PL Faulkner and Pope counties. They also made reference to Alpine repeater in Clark Co.
151.070-123.0 PL Pulaski and Saline Counties.
151.085-114.8 PL Too much static, didn't hear much.
151.085-151.4 PL Too much static, didn't hear much.
151.100-141.3 PL Hempstead and Sevier counties.
151.115-114DPL Highway police in Garland Co. May not be used anymore since AWIN is available.
151.130-151.4 PL Highway Police Not sure which district. Still in use currently with AWIN.
156.105-CSQ This is the Highway Dept for Garland Co. Portables only, need to be close by to hear anything.
156.135-132 DPL Highway police, unknown where, may not be in use anymore due to AWIN.
As far as I can tell I have not heard Garland Co on any of these frequencies other then 156.105 and 151.115.
They use portables so you need to be within a mile or two to hear them. They probably have these other frequencies/channels programmed in their radios too but rarely use them. This is the best time to listen in on these frequencies since its winter time and they are putting salt on roadways/bridges.
Also the South Central Arkansas Transportation Dept also uses a few of these frequencies.
I think it transports disabled passengers on a bus.
altec
Scat buses
Too add the South Central Arkansas Transit buses also use a few of the Highway departments frequencies.
Heres the link to their website. http://www.cadconline.net/
To listen to them in Hot Spring or Garland counties plug in 150.995 186.2 PL (very boring bus chit chat).
Also the frequency 156.105 662 DPL is for the Saline County area bus operations. It mostly comes in as static but didn't want you to get confused with the highway dept. The highway dept operations don't have a tone for this channel so they are CSQ on 156.105.
