HF Acars Decoders and/or Selcal ?
BOBRR
Boston, MA
Hello,
Have a WinRadio Excalibur SDR receiver.
Can anyone suggest any free, or inexpensive, HF Acars decoders ?
(I am familiar with Wacars)
Same question for Selcal ?
Thanks,
Bob
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
While the page I maintain on Mike Chace-Ortiz's site has at least 2 packages that will handle HFDL, I don't have anything on selcalls, I don't think. See my sig
The problem you're going to have is trying to feed the audio into the decoder. I *think* that you need some sort of virtual device to do it, unless there is something that is native to WinRadio that can do it (always possible)
Mike
majoco
Stirrer
New Zealand
Aah - I see - two different posts on the same subject.
PCHFDL is the programme you need but not sure if it's been tested on Windoze 7 - mine works well on XPv3 with WinRadio g303e and the virtual sound card - see your other post.
Decode Selcal? Never tried it or felt the need. I wonder if a DTMF decoder would do it. Somewhere there should be a list of the tones and their allocated letters. Not so long ago they only went up to H as they had to be fairly well spaced as the Motorola decoder in the aircraft just used mechanical reeds as the frequency detector - bit like a harmonica reed - but now it's done in software and they have fitted far more tones in the audio bandwidth.
Thinking some more - a DTMF decoder only gives the telephone numbers so that won't work!
