zguy1243 said:
Im looking to upgrade my HF antenna in the next week or so. For the last few years I have played with random length wires in the horizontal position and some inverted V's. I have used some baluns but nothing of high quality. I listen most of the time from 3 megs to 14 megs. Those of you that are big into HF monitoring may be able to tell me what would be a really good antenna. Somthing of high quality. Most of the stuff I listen to is utility type stuff, military, atc, ect. Any help would be appreciated greatly. I am using a Icom R75 and a Icom R72 receiver.
Jody
KG4FVG
Cover the basics:
Do you want to hear close in (100 - 700 miles)? or distant (700 miles to ??).
For close in, a lower horizontal antenna, either broad band or cut for a specific band will work best.
For 700 + miles, you need a low angle of take off so the antenna needs to be high (50 ft or higher) or a vertical (with a very good ground).
If you can put up one of each, then you've got it covered, put them on a switch so you can go from A to B and back, use which ever is better. Even if you have to just about criss-cross the wires, go for it. One of the biggest DXers of all time, W6AM, had numerous antennas only spaced a few feet apart on numerous telephone poles, so if have to put them fairly close together, fine.
Make your station as versitile as possible, don't restrict yourself to just one antenna if you can help it.
Use the best feedline you can afford. Even "ladder line" works well and isn't that expensive.
Sounds like you know what you're doing, put some money into a few good switches and GO FOR IT!
John K9RZZ
