I've monitored ARINC Pacific, Atlantic and Caribbean HF freqs for a number years, and during those years used various antennas, some a tad on the expensive side. Some worked okay on various freqs, others not so hot. Same comment goes for the Radio Shack $10.99 HF antenna kit which consists of 75 ft of copper wire, 50 ft of plastic coated lead-in wire and insulators. Of all the antennas I've used, this one has been the best. I usually don't run the full 75 ft. The one I'm using now is a little over 50 ft. because of yard/building layout. The longer the antenna, the lower the frequencies you can pull in, so if you can run the full 75 ft., do so. You won't find an inexpensive antenna specifically cut for, say, the individual ARINC frequencies that range between 3 and 20 megs. The 50 to 75 ft. wire will do fine, I assure you.
