updated active pirate beacon list that I maintain at the HF Underground
Recently Reported Beacons updated 06/16/2022, frequencies in kilohertz:
2097.3 "A" Fairly high power, an easy target even out east. Back on air Nov 2021
4086.7 dasher sends about 8.7 dashes / min, each about 1.7 sec long
4094.0 id's UFO TMP three times, after TMP two numbers are sent then back to dashes. On the air around Nov 2020
4095.03 Beacon L sends in slow Morse about 2 seconds apart
4095.170 MudDuck in Morse with ten 1 sec dashes. First heard 1/1/2022
4095.700 "Desert Whooper". Discovered Nov. 16, 2020. Sends "DW" in Morse, then 30 upward frequency sweeps or "whoops" at 1/sec. Repeats five times. Next sends 5 slow whoops, BAT & 3 digit voltage, O TMP then 2 digit temperature, I TMP then 2 digit temperature, PV and solar panel current with values ranging from 0 to over 2000 in milliAmps.
4096.0 "Coxie" Slow dasher, about 4.5 seconds, 700 mW, Joshua Tree NP, daytime only with dead battery
4096.2 Slow dasher called Buddha, was "Phallaxy" was "Viking". About 30 mW, daytime only. On for 3 seconds, off for 3 seconds
4096.85 "Marin Dit", 24/7 5-10 mW, harmonic of 8193.77 radiates better
4097.08 Slow Dasher, 2secs on and 2 secs off. Discovered Nov. 2020, it does appear to be related to 7997.2 kHz. The two dashers appear to be in sync.
4097.1 Fast Ditter. New in 2021
4097.23 Fast Dasher called Madonna, 1/3 watt
4100.01 F
4100.05 H, repetition 3 seconds
4106.86 About a 2 sec dash followed by a 5 sec space
4109.50 "Central Coast Slider" slow whooping beacon, coastal mountains of central CA, 335mW, EFHW antenna, solar/battery power
4175 Z
5644 Y and 2 second dash
6626.2 "Rainy" - Mojave NP, CA - daytime ditter/chirper in Mojave NP, 1.5 watts, first on-air March 2003
6627.0 Gendarme - a whooping beacon, quick-falling in-freq. deliberately the result via a 100 uF cap. on the voltage rail from the 2w panel and the freq. falls during cap. discharges on key-on. 50% duty-cycle/0.5 watts. Somewhere in the southern Great Basin... sun-only
6700.5 "HexY2k" Joshua Tree NP, daytime only, 100 mW to inv. vee, 150 mW first on-air 29 Dec. 1999
7000.65 "Stumpy" Ditter, about 0.17 seconds long, sent every 22 seconds.
7039.4 "T" beacon OK0EPB sends a marker each second, a longer one at the minute, and callsign.
7956 kHz Cry Baby 1/second dasher with chirp, 10 mW solar powered daytime only. Located East of The Continental Divide somewhere high in the Rockies. On the air May 19, 2021
7997.0 kHz dasher appears to be a 2 second on, 2 second off, dash. may be related to 4997.08 dasher
7998.3 "Shorty" sends 18 dashes starting every minute.
7998.9 Ditter, dits about 0.15 secs long, about every 0.6 secs, or about 100 dits / min
7998.9 KHz, dashes of roughly two seconds long with about five seconds inbetween dashes
8000.35 Very long period dasher, 40 or 50 seconds. Sometimes sends a broken dash that sounds more like an A or AE.
8001.2 New beacon as of Dec 20, 2015, 5 second period, frequency 8001.2 - 8001.6
8005 "Hiker", Dit rate is 60 per min. 500 mW into whip antenna.
8006.7 V5 sent 39 seconds apart
8191.9 second harmonic of Coxie on 4095.9
8193.7 "MarinDit" - 24/7 in Marin County, CA - about 80 dits/min. 10-15 mW only - on-air since spring 2000 (an "attic beacon"), this is the second harmonic
8200.15 D, repetition 3 seconds
8498.5 Fast Dasher dits are about 0.14 sec long, and about 0.6 sec apart, or about 100 dits / min
8500.3 Slow Dasher
