hi
robbie2
hi there i was wondering what is the input freq, for the cougar MT repeater,
146.980 i just need the input freq,
also the king county SAR 145.1100 i need the input freq for this repeater too.
thanks
robert,
zerowatts
I could be wrong but I think is not the right forum for that question? there are forums below that are sorted by state though I think. :)
Good luck.
Mod feel free to remove my post when the right place is found. ;)
n5ims
The 2 meter band has standard repeater offsets so most input frequencys are easy to figure out. The input frequency (what the user transmits on) is 600 KHz away from the repeater's transmit frequency (what the user listens to). Most amateur radios have these offsets already preset so if you tune to 146.98 MHz, the radio knows that this frequency has a negative offset and will set itself to transmit on 146.38 MHz. There are a few frequencies that could go either way (such as 147.00 MHz) and the repeater listing will indicate if there's a + or - offset (you'll need to configure the radio to match manually).
This link has a chart listing the standard offsets on the 2 meter amateur band. Standard 2-Meter Amateur Radio Repeater Input Frequency Offsets
robbie2
the 2 meter band has standard repeater offsets so most input frequencys are easy to figure out. The input frequency (what the user transmits on) is 600 khz away from the repeater's transmit frequency (what the user listens to). Most amateur radios have these offsets already preset so if you tune to 146.98 mhz, the radio knows that this frequency has a negative offset and will set itself to transmit on 146.38 mhz. There are a few frequencies that could go either way (such as 147.00 mhz) and the repeater listing will indicate if there's a + or - offset (you'll need to configure the radio to match manually).
This link has a chart listing the standard offsets on the 2 meter amateur band. standard 2-meter amateur radio repeater input frequency offsets
thanks for the help,
kc4jgc
Virginia Beach, VA
Are you sure the repeater output isn't 146.985? 146.98 is not a standard repeater output; .985 is.
In most areas the spacing in the 146-147 MHz portion is 15 khz repeater outputs starting at 146.61.
