HM782 - Always-on setting?
phadobas
Is there an always-on setting for the HM782? I'm putting it into a vehicle and don't want to mess around with another cable for the ignition-sense. I just want the radio to turn on as soon as it gets power.
dazey77
yes, physically wire the ignition sense to the 12V supply! AFAIK its the only way, I have a MD785 wired like that.
phadobas
Yes and that requires a DB26 connector, which I have made for several vehicle in the past, but I've got a few new ones to install and was wondering if that's even needed. It does seem like (at least in my office) I can make it so that as soon as there is power provided by the power supply, the radio turns on. You can turn it on and off with the ON/OFF button, but it automatically turns on when power is applied, and of course, it turns off when power is turned off. This is pretty much what I need. I have to see if it works well like this in a vehicle also.
VK6NCB
the HM782 we are installing in mining vehicles turn on automatically when they recieve power, and dont need an ign sense wire.
the only time we use ign sense wire on HM782 is when they are run as a base station, and the power button is disabled in the software, to work around operators turning the radios off. doesnt stop them unplugging the PSU at the wall though.
phadobas
Ok yes, I found the same now. Simply turn on the ignition to provide power and the radio turns on. I wonder what's the whole point of the ignition thing is. Few years ago I went through the trouble of custom-making those DB26 connectors to connect the ignition sense pin to the ignition. Now I see it wasn't needed. But then when do you need it?
Even in the above example of using them as desktop station, you can just disable the power button and make it always-on, no?
VK6NCB
Its been a while since i programmed it - but if i recall correctly it wouldnt power on automatically with the power button disabled in software, it needed to follow the ign sense.
operator proofing stuff can be a fun exercise.
