jccampbel
Home Patrol 1 is suddenly malfunctioning, cycling on when power button held, appears to be normal start-up, gets as far as loading favorites list, then very briefly displays normal screen when scanning. Then the unit goes off, and immediately repeats the entire power on process. The cycling will continue until I hold the power button to turn it off. This happens both with battery power and with A/C power. While turned off but A/C power plugged in, it started beeping and displaying "Charge battery...yes or no", hit "No", then in just a few seconds, same thing again, over and over. Any thoughts about what is failing? Would a new software install possibly help, or is this definitely a hardware issue? Repairable? Thanks. JC
