prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,999
- Reaction score
- 15,513
A good quality SO-239 or PL-259 is good to at least 500MHz without anything to worry about. Even Motorola uses them on duplexers past 500MHz where the signal is passing through four sets of SO and PL connectors and there is no significant loss to speak of.
Using an SO-239 as an antenna junction at 800MHz should also not be a problem because you can tune the vertical element to resonance with the connector in place and it becomes part of the antenna.
prcguy
prcguy
Why do all the photos of the "sputnik" look like the 2 shorter vertical elements are the same size?
Also, while the SO-239 really fits the bill mechanically, isn't it a bad choice above 300MHZ due to impedance issues?
I'm planning to build one soon, trying to decide on the best mechanical configuration, will likely use an F connector as I have tons of 'em and they're dead simple to install on RG6, but a chassis mount F isn't conducive to 4 radial and 3 vertical elements.
