Would this make a good antenna for an RTL-SDR? Homebrewed Off-Center Fed Dipole Scanner Antenna.
Bellingham_Scanner Member Joined Mar 21, 2010 Messages 237 Location Bellingham Washington May 27, 2013 #1 Would this make a good antenna for an RTL-SDR? Homebrewed Off-Center Fed Dipole Scanner Antenna.
D DaveNF2G Guest May 28, 2013 #2 If it makes a good scanner antenna, why would it not also work for SDR?
searingxheretic Member Premium Subscriber Joined Aug 30, 2007 Messages 231 Location Richmond, VA May 28, 2013 #3 Please don't post the same question in multiple areas. You got some really good answers and a bit of a debate to consider in the other thread you started. http://forums.radioreference.com/showthread.php?t=267596 Sent from my cm_tenderloin
