freqhopping
- Joined
- Jan 5, 2004
- Messages
- 7,096
A while back I attempted to use some Rayovac Ni-MH batteries to make a battery pack for my BC250D. I wired it exactly as the original. But I seem to have burned up something in the scanner.
It started smoking so I turned it off immediately. It would still work with the original battery (until it ran out of juice), but the AC adapter input will not work and I can not charge the original pack using the scanner. The Rayovacs are rated at 1300mAh, but I wouldn't think that would be a problem. I've been running the scanner on the DC 12v 10Ah power from my motorcycle just fine. I've made some adapters to plug into the battery pack port so I can still use AC and DC sources.
What are my battery packs options other than a new original? It doesn't seem that there are any 4.8v/1500mAh options from Radioshack. Or what is the proper technique for a DIY battery pack. I need to find something during the time I send the scanner off for repairs.
