Homepatrol 2 antenna
RS8
Winchester Virginia
I am using the stock antenna for my Homepatrol 2. It works Ok but I was wondering if there is a better INDOOR antenna out there for this scanner?
Voyager
Better for what? Better for one specific band? The answer is likely yes.
Without knowing what your interests and requirements are, it is impossible to be more specific.
RS8
Winchester Virginia
Homepatrol 2
The area I live in will be mostly P25 Phase 1 and 2. Also Motorola Smartzone. The phase 2 is TDMA.
LakeErieLarry
P 25 receive
800MHZ rubber ducky works very well on the Hp1..so should do the same on Hp-2 I would think..
UPMan
In Memoriam
Arlington, TX
Modulation (FM, AM, P25, etc) does not really matter. What matters is frequency band (400 MHz, 800 MHz, etc).
