HP-2: Homepatrol 2
MississippiPI
All over the Great State of Mississippi
I have read the post and still can't get it to work, I get the error message. Batteries are good, new USB cable, new 32kb card and still nothing. Any suggestions? I emailed Uniden week ago and tried support and no luck with response.
Thanks ya'll
hiegtx
Dallas, TX
Thanks ya'll
What error message are you getting?
donc13
Grand Junction, CO
Thanks ya'll
32 KB card? Way too small. Try an 8 GB card. The new USB cable, is it a full USB cable or. just a charging cable?
JoeBearcat
Uniden Representative
I was asking about where the card was purchased from. If a scanner dealer, it may be set up for the scanner. If from WalMart (or alike), it will not be set up for the scanner and you have to use the CLEAR USER DATA function to 'format' it for scanner use.
fxdscon
¯\_(ツ)_/¯
Oh ok, I got a new card from a retail store, associate of mine formatted it,still didn't work
As others have noted..... a new (or newly formatted) card will not work in your scanner until you use Sentinel's "Clear User Data" utility.
Put the new card in your scanner, connect your scanner to your computer in "Mass Storage" mode, run Sentinel's "clear user data" function and check the box that says "display all drives" when that function starts, then click "Ok". When the process finishes, disconnect the USB cable and the scanner will re-boot.
You may need to connect your scanner to the computer with the USB cable while the scanner is OFF... after connecting the cable to the scanner and computer, turn the scanner ON to go into "Mass Storage" mode.
