HomePatrol Sentinel update
Saskatoon, Saskatchewan
Hello all,
I opened Sentinel today to update and re configure some of my lists when the program told me there was a newer version and I was required to download it. I clicked on the link provided and it sent me to HomePatrolSentinel < HomePatrol < TWiki which is the 2014 update.
Does anyone have a link or know where I can find this alleged update Sentinel is telling me I must acquire?
Thank you,
Andrew
155604
I already had 2.03.02 installed. I figured it was worth a shot uninstalling and reinstalling. Same message as before. Still says I need to update Sentinel. I emailed Uniden and hope to hear back within a few days.
brennin
I just noticed this same problem with my sentinel. Hopefully, if enough voices speak up, Uniden will cure the problem ! :giggle:
ProScan
Software Provider
Ontario, Calif.
It works here using Sentinel 2.03.02. I updated the database from date of 12/09/16 to 01/20/19.
It may have something to do with the OS Region settings.
Check if the date is in this format: DD/MM/YYYY. For a test, change to MM/DD/YYYY{edit} this is the NORMAL date format
Also check if the Decimal Symbol is a period or comma.
{edit}
Also try deleting this folder. Exit Sentinel first.
C:\ProgramData\Uniden\HomePatrol_Sentinel
Restart Sentinel. You should see a message "Reconstructing HomePatrol Database"
fxdscon
¯\_(ツ)_/¯
Working here also... using 2.03.02 for quite some time and have not had any problems using Sentinel or updating. Just updated database a couple of minutes ago with no problems.
palmerjrusa
Frederick
So what is the latest version of Sentinel?
I tried updating from the link and it says I'm running:
Version 2.01 (revision 01)
brennin
I just checked my sentinel and it appears to be corrected. Some other posts eluded to the problem being on Uniden's end, Glad they corrected it.
