Horry Co Fire
mcrabtree
I was looking in the database and can't find a fire disp for Horry county. I'm guessing they still use the Horry Co P25 system?
Tobydog
Look at the RR database in Horry County. Calls for service are dispatched on HCFR Tac 1,2,3. There is no Dispatch as such, stations get alerts on digital pagers. All other radio traffic is on Tac 1, Tac 2 and Tac 3. Program those 3 TG ID and you won't miss a thing for fire calls. Myrtle Beach and N Myrtle Beach have their own talkgroups but are also dispatched over Horry system
Tobydog
Additionally, system is totally simulcast, plan for the issues on monitoring
mcrabtree
I have everything programmed I just didn't see a designated disp channel. I have the sds100.
fpo701
OH DB Admin
Akron, OH
In the SDS100, the three channels named Tac 1 North, Tac 2 South, and Tac 3 Central will show a Service Tag of "Fire Dispatch". There's no "dispatch" channel for Horry County FR. Tac 1-3 are used for dispatch and operations. Then, larger incidents are moved to the other tac channels as needed.
Scannerham62
Surfside Beach, SC
Some changes were recently made with the new Purvis dispatch system coming online.
Tac 1 is Battalion One (North)
Tac 2 is Battalion Two (South)
Tac 3 is Battalion Three (Central)
Tac 4 is Battalion Four (West).
Tac's 5, 6, 7, 8, 9 are assigned on an "as needed" basis for Incidents, (starting with Tac 5).
KE4SZT
Marion, SC
Does anyone know if the new Purvis dispatch channel is carried on the TRS or maybe a conventional channel?
k3sls
FM03qu North Myrtle Beach SC
Is there some type of district map that geographically demonstrates the North, South, Central and West districts?
The best you can do is visit the station and response area map at Stations - Horry County SC.Gov and click on each station. The resulting multi-frame pop-ups will list station details, including the battalion#. From that info, build your own list. Tedious, but you only need to do it once!
Steve162
North Myrtle Beach, SC
Does the interrupted tone alert actually activate station decoders or is it just to draw attention to a pending dispatch?
Steve162
Its just an annoying noise somebody came up with. It doesn't do anything, (except - yes - draw attention).
It's like fingernails on a blackboard...assuming you're old enough to remember blackboards.
It sounds like the old 1500Hz interrupted tone signalling system that we used in NJ on the HEAR radio network (155.34)
I would overlook the annoying tones if the dispatchers had consistent volume. Some are loud and clear, others sound like they're across the room. I wonder if they're keeping the headset mike boom up by their eyes or down by their neck.
Scannerham62
Surfside Beach, SC
YES!! We have the same problem hearing them while on duty. They use noise cancelling headset mikes and they tend to get to far away.
Steve162
It seems that HCFR is not announing incidents on any of the Tac channels. I've been monitoring all of them and nothing.
Anyone know if this is permanent? I guess if they have pagers and in-station voice alarms it's kind of redundant.
IronsMan
It is permanent. There is a separate dispatch channel with automated Purvis call announcements, but it is encrypted.
Steve162
It's probably just as well. Seemed like a waste of air time, and as I commented above, many times the audio was simply unintelligible.
