Hospital communications issue
Mike_G_D
Vista, CA
I put the BNC T on the VNA and had N to BNC adapters on the T, no cables.
Hmm, in that case, I either suspect the calibration or the quality of the connectors and/or dummy load.
1) Was a full calibration done at the test frequency using lab standards, open, short, and load?
2) What is the rated frequency range of the dummy loads used on the T.
I can see some reactive component from the T and BNC adapters but the test frequency seems a little low for that to contribute much. Anyway, the real part confirms the overall point: two 50 ohm loads in parallel = expected 25 ohms (or close enough).
-Mike
Pittsboro IN
I didn't look at the T closely, the first one I pulled out of the bag had the center conductor for the long part of the T sticking out on one side, so quality is probably an issue.
I calibrated the device at IWCE with an Anritsu cal kit another instructor had, I don't own one but plan on getting one. I have a hard time spending $300+ for a calibrated open and short. The VNA has not been factory calibrated for 3 years, hard to believe I've had it that long.
It is nice to see theory and measurements agree.
Mike_G_D
Vista, CA
At this frequency and for this purpose, just using an SMA female pcb mount with the through mounting legs soldered to the center pin for a short and another with nothing (preferably with the mounting legs cut off) for the open should be good enough. And if you lack a load, use another with a small (say, 0402 size) 50 ohm surface mount resistor (the tighter the tolerance the better) soldered between the center pin and the outer shield, again, with legs cut off preferably. I did this a lot when lab standards were not easily available and it gets you pretty close.
