Hotlines
licpl8man
Southbury, CT
Just curious, is there a hotline for Litchfield County similar to FAPERN or the New Haven hotlines? I just heard the Southbury dispatcher refer to getting a call from Troop L on the hotline but it wasn’t on any of the hotlines I have programmed both conventional or on CLMRN.
Thanks all
izzyj4
Ova here
Troop L had access to the New Haven and Hartford 45.86 hotlines (different PLs) and also the old WARN (Waterbury Area Regional Network) UHF police hotline on 460.300. There are also "hotline" talkgroups on the CLMRN system they have access too as well.
cg
Connecticut
The various low band 45.86 hotlines are patched to CLMRN, on tgs 5295, 5395, 5495 Fairfield county uses 5195 but no idea what (if anything) it is patched to.
Some dispatch centers are now using CSSI which is essentially a direct intercom between properly equipped centers. Beats dialing your neighbor psap regularly.
iowa9015
Waterbury, CT
Thanks all
Litchfield County/Region 5 does not have a hotline like Region 1, 2, 3 and 4 do.
Like cg said, what you’re probably hearing referenced as "the hotline" could be a console-to-console intercom within CLMRN using CSSI. A lot of centers still use the term generically even though it isn’t an RF-based hotline.
These are basically core-routed console-only voice paths/resources on the system that aren’t carried on any talkgroup or frequency, so there’s nothing to monitor. Only CLMRN consoles with permission can monitor or transmit on them.
KB1JHU
Milford, CT
I have heard FAPERN and UASI Calling used in a similar fashion in SW CT.
Danbury. Troop A, Brookfield & New Milford use FAPERN like it's a hotline. Region 1 UASI calling ends up getting used like a hotline for some FD stuff because phones are apparently too hard to use.
pvnh
CT
LCD has a direct link to A, B, L, and NWCTPS on their consoles, nothing to listen to with a scanner
cg
Connecticut
I believe that is a function of CSSI, essentially console to console talking. Eliminates the need to dial up a neighboring dispatch center but instead talk like an intercom
Firebuff66
CT
Just FYI the Hot lines/FAPERN/UASI Calling etc. etc. are used like that so more than 1 dispatch center can hear the message at the same time, this speeds things up and allows for better operational awareness for departments close to the the incident but not involved yet.
Let say I was a dispatcher, and I worked at a regional center, and I had 70 channels on my console and I actively use about 14 all the time, and the rest were used sparingly but in times of need, I would want to be able to use 1 channel to talk to mutable centers to get my message out quickly, instead of making 4 or 5 phone calls while managing the incident, and taking 911 and routine phone calls
iowa9015
Waterbury, CT
Lets say! :LOL:
izzyj4
Ova here
| - Difference between being a dispatcher / emergency telecommunicator versus the regular public right here.
nhfdcadet
CETsr
New Hartford, Ct
Imagine if the regional dispatch center would even go as far as to multi-select their towns that go to the same call, instead of doing 3-4 different dispatches for the same incident. Now we're getting somewhere!
nikronzo
4.X SloppyCast
Do you mean to say that the technology exists to key multiple TGs/channels at once instead of having to repeat the same BOLO 6 times over 6 channels, or dynamically regroup a pool of radios to the same channel to ensure everyone at a incident is correctly talking to each other. :eek:
izzyj4
Ova here
I'm a dispatcher. There's a huge amount of chatter on these channels at times that strictly involves the two agencies where other agencies really have no need to know about it.
Your going to get that regardless. Being a former dispatcher, and for a time at Troop I, I rather have the the huge amount of chatter between two agencies than not. You never know when its gonna roll over into your district / town. Especially if its a chase or multi agency incident.
izzyj4
Ova here
Well the problem is dropping tones at the console. When you drop the tone for an agency with its own frequency / channel, it usually drops the patch link and only redirects to that module. Obviously it depends how the console is set up and the programming of it. When I dispatched for C-MED New Haven, all the departments had their own frequencies. But depending on how many of us were on duty and our availability, we each drop a department's tone at each individual console, then the dispatcher who handling the call could key up all the modules at once and do a multi dispatch. Then hit the patch so everyone could hear each other. Of course this was on an old Centrcom console. We tended to get creative. We used to do it between Derby and Ansonia Fire for calls at Griffin Hospital since it was a dual response.
But also with regional centers, you may not want to drop all the tones at once. I have hear multiple regional centers drop stacking tones for over 1 minute or 2 where the actual information dispatch was very brief.
The only perfect solution would be the one where the dispatcher makes the determination what is most important to get out first. That's how were are usually trained.
nhfdcadet
CETsr
New Hartford, Ct
Modern consoles don't behave like that, the tones can be simultaneously sent over multiple resources (by one person), and those resources can be multi-selected by the dispatcher and he or she can transmit the message over all of them at the same time. Derby and Ansonia are a perfect example, with the amount of mutual aid they do together, it doesn't make sense to dispatch one, and then the other to the same incident when one person could do both at the same time.
It also doesn't make sense that whenever there is a fire in the valley, every single responding department stays on their own channel and establishes their own incident command no matter where the fire is or who the actual incident commander is. "Unified command?" whats that? :ROFLMAO:
