How am hearing this?
JamesBrox
Santa Rosa County, FL
I'll make this short and to the point. New to gmrs, I have Wouxun KG-1000G+ mobile as a base unit. With a gmrs tuned Ed Fong antenna is 40' up.....I'm happy with the performance of the set-up. I'm in my shack scanning the repeater channels (RPT-15thru22). I'm hearing on RPT 17 a round table discussion from folks in LA, TX and even farther. How? GMRS is line-of-sight, correct?
James WRXU693
Many GMRS repeaters are linked via the internet. Sounds like your local repeater is, and it is linked to repeaters in at least LA and TX. Not uncommon.
JamesBrox
I see. But It's that kinda cheating? Lol. Isn't gmrs supposed to be just CB 2.0 but you have to have a license? I know with gmrs, you're allow to use repeaters so it's a whole different ballgame.
Well, there's two camps, one on either side of the GMRS river.
One camp has been there a long time and wants GMRS to stay as a family radio service where someone can put up their own repeater for their own communications amongst their friends/families and have a good radio system without a lot of noise, interference or channels being tied up.
On the other side of the river is another group. They want to be able to use GMRS as a hobby radio service where they can carry on rag chew sessions across the country. They link their repeaters together so they can do this. Much like what gets done on amateur radio.
The traditionalists like things the way they were.
The new guys want to cram a lot of stuff onto 8 frequency pairs, even though there are often repeaters sharing the same frequencies.
Both sides like to argue, throw rocks, and generally insult each other.
Sometimes you will hear GMRS referred to as CB 2.0.
Sometimes you will hear GMRS referred to as ham radio 2.0
Amateur radio already has the linking thing well established and has plenty of room to do this. However, some GMRS users can't/won't get their ham license, so this stuff happens on GMRS.
I'm neither for or against it. I just think people need to understand it is a limited resource and needs to be shared. It's also not hard to get an amateur radio license….
smittie
Dillon, Montana
I should probably just take a leap and get my HAM.
For some, GMRS is wanna be HAM. For a lot of my clients GMRS is a business itinerant replacement.
JamesBrox
Interesting point of view.
I decided to try gmrs for local comms only. But the more I learn about it, the more involved this hobby CAN become. It's crazy. My first major hurtle was RX/TX PL tones and how they're not truly private at all. lol
JamesBrox
I decided to try gmrs for local comms only. But the more I learn about it, the more involved this hobby CAN become. It's crazy. Plus....I'm not a big talker to be a ham. Honestly, I don't have that much to say to folks.
Interesting to of view.
Yeah, PL/DPL tones have nothing to do with privacy. It just keeps you from hearing others. Unfortunately a lot of the consumer users can't comprehend coded squelch systems, so the manufacturers just called it "privacy" as a simple explanation.
If you just want to use GMRS as local communications, you will need to try and find a local repeater that is not linked and will let you use it. Or, put up your own (not an easy task).
If simplex will do what you need, finding one of the more obscure PL tones or DPL codes is a good solution. I did that for years. I had access to a high level repeater with my own obscure/non-standard PL tone. I also used one on a simplex channel. Usually didn't hear anyone else.
KB0VWG
What you are hearing is sites connected via gmrslive.com
You purchase a raspberry pi3b and a pi hat and connect to gmrslive and you can connect with other networks.
I have one and I use my ht to dial into a node and it connects me to Michigan, new york Louisiana etc
Its like a dmr hotspot but gmrs only. IF a repeater is connected to the internet then it can connect to any hotspot or other network via typing in the node number.
wrpu444
kb0vwg
JamesBrox
Yeah, a good antenna will make a big difference. I've talked 15+ miles mobile to mobile before on GMRS, 1/4 wave antennas permanently mounted on the roof of full size trucks.
Unfortunately many cut corners on the antenna system, then wonder why their radios don't work.
Yes sir, the expensive radio is worthless without a good quality antenna and coax.
JamesBrox
wrpu444
kb0vwg
Man, that's wild. Question : So I just heard a guy in Bakersfield, CA on RPT channel 17 462.600/467.600. Does that mean he's TX from a 600 RPT in Bakersfield, into the internet then his comms RX a 600 RPT near me? I'm hearing the RPT ID is the "Roadkill Network".
alcahuete
Southern California
Doesn't have to be 600. It can be any of the GMRS repeater channels. It's just linked.
alcahuete
Southern California
I'm hearing the RPT ID is the "Roadkill Network". Where this at?
JamesBrox
I see the list of "Friends" repeaters in this group. But my base antenna is very far from New Orleans (190 miles away). I assume this is propagation?
alcahuete
Southern California
No, not that far. I'm assuming there is a repeater nearby that isn't on the list. And who knows when that list was last updated. The Tampabay Radio Group on that list might have repeaters all over the place in Florida. Who knows?
