How can I interface the antenna to a computer???
ypyp
Good Day,
I really have a big problem with our thesis, its an antenna positioning system using ant colony optimization. Basically the antenna will point to where the maximum signal strength is received. Its more on programming, but were having a problem with the hardware. We don't know how can we interface the antenna's received signal to the computer.
Were using a Labjack for the ADC part, but the Labjack can't be directly connected to the antenna. Our antenna's receiving frequency is 914.5 MHz.
I hope you can really help me with this, I really need some suggestion regarding my problem.
zguy1243
Calhoun Georgia
Im not sure of your exact situation but taking a voltage reading from the correct RF section of a radio or S meter voltage would be a constant variable that you could base software on. Should be simple.
