How do I find my school's frequency with a Baofeng UV-5R
buddrousa
Would these steps help me to get into their frequency?
  1. Turn on your Baofeng UV-5R radio.
  2. Press the VFO/MR button to switch to VFO mode.
  3. Use the up and down arrow keys to select the frequency range that you want to monitor. For example, you can select the VHF or UHF frequency range.
  4. Use the up and down arrow keys to select a specific frequency that you want to monitor.
  5. Adjust the squelch level to an appropriate level. The squelch function on your Baofeng UV-5R is designed to filter out background noise when there is no incoming signal on the selected frequency. Adjusting the squelch level too high may filter out weak signals and cause you to miss transmissions, while adjusting it too low may result in excessive background noise. You can adjust the squelch level by pressing the menu button, selecting the "SQ" option, and then using the up and down arrow keys to adjust the level.
  6. Listen for any transmissions on the selected frequency. If you hear a transmission, note the frequency and any other relevant information, such as the content of the transmission and the time of day.
  7. If you want to save the frequency for future use, press the menu button and select the "Save to Channel" option. You can then select a channel number to save the frequency to.
Do you understand what you are asking about?
Do you understand that unless the schools allows you to use the radio you may be breaking the law?
Do you understand that this could end up causing you to removed from your school?
KevinC
The big K
Super Moderator
I'm everywhere Focker!
