I did a project which is two 5 volt USB powered fans that are attached to my router for cooling. I measured the Amp consumption and both fans use around 500 mA total. As a safety measure I would now like to add a fuse, but not sure what Amp rating to use. I'm not sure what determines the Amp rating other than I know I need a fuse over a 5 volt rating and probably slow blow since these are fans. Judging by the 3 Amp fuse in my mobile scanner that consumes around 500 mA at full volume, the fuse is rated at 3 Amps, so that would be 6 times the value. Would I then use a 3 Amp fuse for these fans or what?
