I've added the electric Co. 3 DMR frequencies. I hadn't had any traffic on them all day which is odd. When looking at the display on my SDS 200 while locked on the channels manually, I noticed there was no talk group. The talk group is 100 when programmed using Proscan. It shows color code 1 which is usually there. Do I need to manually add the talk group 100 some how? Thanks!
How do you have this programmed?
If programmed as conventional frequencies, you cannot include a talkgroup or slot designation, though you can use the color code.
If programmed as One Frequency Trunked, you can program the talkgroup & slot if so desired, as well as the color code.
For any conventional channel, or talkgroup ID (whether in an OFT system, or a trunked system with the LCNs specified), be sure that you have the appropriate service type enabled.
I don't see the electric company system listed on your county's database page. Did you get details from a local source?
Can you export your Favorites list into an *.hpe file? You will need to have Sentinel create & save that file. Then, using File Explorer, locate the file & <right><click> on it to get the option to compress it into a zipped file. The zip file can be attached to a post here in the forums. Or, you simply post your ProScan file for the Favorites list. ProScan uses the text (*.txt) file extension, which can be posted on the forum without having to create a zipped file.
