How to block Harford County Bus Dispatch?
dudleydog1
Anyone know how to block out the bus radio dispatches in the Harford County system? I blocked the one ID identified as #12 Harford transit but still get the bus traffic when monitoring the Fire and Police channels. It would not be so bad if they didn't talk like they were on a CB or cellphone tying up the airwaves. There must be some other IDs not labeled that need to be blocked.
Dewey
It would be a big help if you told us which scanner you are using. This could be a couple things on the Unidens... I-Calls or ID Search.
Dewey
kilowa22
Oregon
If you are using a Radio Shack scanner after locking out a TGID you must but the Bank in Closed mode.
dudleydog1
Radio is a RadioShack PRO-96
Using a Pro-96 and Win96. Checking the LOut next to the ID identified as Harford Transit.
dudleydog1
Thanks to kilowa22, closed the bank and that took care of it.
