Have some APX-7000s that use AES256, which the keys are loaded using a KVL3000+.
For interoperability with a particular system, I need to add an ADP key (while still keeping AES active in the radio). When I check the radio's hardware algos using service mode, I see both AES256 and ADP listed as present. However in CPS, when hardware is selected for the encryption type, the ADP key fields are greyed out. I think that's because the ADP keys need to be loaded with the KVL if I plan to use AES256 also (meaning it's all hardware based)?
If so, is the software upgrade necessary to add ADP to a KVL3000+ still available from Motorola?
