DSDPlus How to write .amb
Sphex
Hello everyone. I'm still a beginner, maybe my question will seem stupid to you, but I'm asking for help. I need to write an .amb file during dmr transfer, but no software I have (SDRsharp, dsd fl 2.71, sdrtrunk) can do it. Please help the newcomer to figure it out.
P.S I have windows 10 x64 and RTL-SDR v3
Thanks ❤️
Reconrider
Inside the Galaxy
Radio Galaxy
Explain more on what you want because I'm lost.
You can use dsdplus fastlane to record raw audio but no idea what you're actually looking for
Sphex
I need an .amb file recorded during transmission with encrypted voice on frequency. So that I could see all the metadata (xor) that was transmitted. Sorry for my English, I use a translator
Reconrider
Inside the Galaxy
Radio Galaxy
Ahh. You can use DSDPLUS and dsd-fme.
You MUSTT record the audio as RAW RECORDING and then you can use dsd-fme to see the AMBE frame information.
lwvmobile
DSD-FME
Lafayette County, FL
If it were me, and I just had to write some .amb files for DMR into a folder called mbe in the current directory, and wanted to use an RTL dongle as input I'd do it like this:
dsd-fme -fs -i rtl:0:154.9875:0:0:12 -d mbe/
If you were wanting to fine tune the parameters on the RTL Dongle, like frequency, PPM or gain, this would be the legend for that:
Code:
RTL-SDR options:
 Usage: rtl:dev:freq:gain:ppm:bw:sq:vol
  NOTE: all arguments after rtl are optional now for trunking, but user configuration is recommended
  dev  <num>    RTL-SDR Device Index Number or 8 Digit Serial Number, no strings! (default 0)
  freq <num>    RTL-SDR Frequency (851800000 or 851.8M)
  gain <num>    RTL-SDR Device Gain (0-49)(default = 0; Hardware AGC recommended)
  ppm  <num>    RTL-SDR PPM Error (default = 0)
  bw   <num>    RTL-SDR Bandwidth kHz (default = 12)(4, 6, 8, 12, 16, 24)
  sq   <num>    RTL-SDR Squelch Level vs RMS Value (Optional)
  vol  <num>    RTL-SDR Sample 'Volume' Multiplier (default = 2)(1,2,3)
 Example: dsd-fme -fs -i rtl -C cap_plus_channel.csv -T
 Example: dsd-fme -fp -i rtl:0:851.375M:22:-2:24:0:2
When in doubt, just look at the myriad of example usage, or check the help with dsd-fme -h
Of course, if all you want to see is the AMBE payload, just run with the -Z option.
If you don't specifically need the .amb file, then I'd just run something like:
dsd-fme -fs -Z -i rtl:0:154.9875:0:0:12/
Sphex
Code:
RTL-SDR options:
Great, thank you very much for the detailed answer. The other day I'll sit down with a cup of coffee and figure everything out, I'll dive in) thank you
