HP 2
flborror
Was wondering about using an HP@ in Illinois for Bond Madison and Sangamon county. I believe some area or departments are simulcast any ideas on how this would work or suggestions
Thank You
flborror
If you have a known simulcast system or site you're trying to monitor, go with the SDS scanners.
Thanks i dont know about any beside starcom out in the bond county area was wanting to set one up as a gift
werinshades
Chicago , IL
Scroll to the county in question, go to the site name on the left, click on it and will open a map. If you see more than one "pin", it's more likely than not a simulcast site. If the scanner is staying in one spot, and within a non-simulcast trunking area, it would be ok. If there's a chance it will be mobile, go with a SDS scanner.
Starcom21
IL /MO/Global DB Adm!n
Madison and St Clair are the only 2 simulcast sites.
However if you are out of these 2 counties, there is a good chance you will only receive one the sites (of the simulcast) and it may work ok.
