hp2 data base fail
cistercian
north carolina
I just updated my hp2. It no longer disregards areas far away...I had to avoid all systems across the state.
This bug sucks and should be fixed. Fail, epic. It no longer cares what distance the services are.
Please let me know when this is fixed.
Until then, my trx-2 is the default scanner.
hiegtx
Mentor
Dallas, TX
Make sure you don't have 'Full Database' and 'Nationwide Systems' selected.
jonwienke
More Info Coming Soon!
VA
Also make sure your Range setting is no more than 5 miles. Setting it too high will cause the behavior you describe.
marksmith
Anne Arundel County, MD
Agree.
Nothing in the database would cause such a problem. Only the way you program your radio would cause such a situation
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
jonwienke
VA
Most likely cause is Range being set way too high.
ur20v
The Feds say my name hot like when the oven on
NOVA
I had a similar frustrating experience with my 436. When I turned the distance down to 5 miles (which is still too broad for my preferences and location) I really began to enjoy the scanner.
This is not to say the database is perfect or without faults - far from it. Whenever I am driving to Massachusetts from Virginia and get near New Jersey or NYC, some numpty's corrupt database contribution changes my CloseCall from DND to Priority. And no matter how many times I change it back, it keeps changing, over and over, until I get away from the area with that entry... and certain federal systems lists scan sites from across the country, regardless of the distance setting or the GPS being plugged in.
jonwienke
VA
Some federal systems actually have sites across the country.
Database data doesn't change close call settings. Ever. The scanner rebooting without saving changes will revert any setting changes made in the menu to their previous value. But database data doesn't change any menu settings.
"Nationwide" systems categorized as such in the database will generally be scanned in their entirety regardless of GPS.
ur20v
NOVA
As much as I'd like to prove you wrong, I just don't have the time to scour the database and drill down to find the offending entry, putting it on display for the world to see. But this happened to me on several occasions, in the same areas, with the same result. There was no rebooting of the scanner involved.
As for "nationwide" lists, well, if I turned those off, I'd have nothing to listen to while traveling. Again, I don't have the time to sit down and create any kind of custom list that matches my travels. Kinda defeats the purpose of a database scanner with GPS location. Seems to me someone was just being lazy in creating the federal systems lists in question, which is odd, because they went through the trouble of including the precise location of each site in the alpha tag. Maybe they thought they were doing it the right way, I don't know. But having sites in Clackamas, Oregon, or Snohomish, Washington, among several others, included in a list you're trying to scan locally in Northern Virginia doesn't do much for the listener.
jonwienke
VA
I have been GPS scanning for years, and have never had my Close Call or any other menu setting change due to a database entry. Ever.
I checked in Sentinel and and there are no trunked systems in the nationwide section of the database. Nationwide systems with sites all over the US have all of the sites listed, but that doesn't mean the scanner is scanning every site in the system, unless you imported the system to a favorite list and turned off Location Control--a flagrant user error. The scanner only scans sites it thinks are in range, based on the location data for the site, your Range setting, and the scanner's current location setting.
I doubt you are actually scanning a Snohomish site while in Virginia, but if you are, be a pal and submit a correction to the database so that the error is fixed for everyone.
ur20v
NOVA
I don't use any custom or favorites lists. I scan exclusively off the Sentinel database national list with specific lists and service types selected... And don't get me started on service types and database entries - a certain P25 system that I monitor is classified under "emergency ops" and the system includes fire, EMS, court security, and a local PD a few towns over, none of which I have any interest in listening to (which is why I don't have any 'EMS' or 'fire' service types selected). But if I turn off "emergency ops", I lose that systems sheriff's office channels I want to monitor, even though all the 'law' service types are selected.
jonwienke
VA
Again, if there are errors in the database, it's easy to submit corrections--the "Submit Info" button on the top of every RR page. If you know of an error and don't do anything to correct it, you have no right to complain about it. And you're screwing over everyone else who listens to that system.
It's not that hard to add stuff to a Favorite List, and tweak the Service Types and other info if there are errors. It's also a good way to verify that your changes are correct before submitting them.
phask
zanesville
If they are all on the same talkgroup, not much you can do, if different TG - just avoid them.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Please post the name/location of the system so we can look at it in the RRDB.
To the OP: Something you did caused the scanner to start "no longer disregard[ing] areas far away". The first thing that comes to mind is you've set "Location Control" to "No" (or "Off", whichever it's called).
UPMan
In Memoriam
Arlington, TX
OP confusing Main Database with Nationwide. Nationwide refers to systems in the HPDB that have coverage nationwide (like CB, GMRS/FRS, Aircraft, etc).
Main Database is the complete HPDB (all systems brought in from RadioReference including nationwide and local systems).
wa8pyr
Lead Database Admin
Ohio
Entirely correct. If you know of a specific error, please submit so it can be corrected; otherwise it's going to stay as it is. While we're more than glad to make specific corrections when errors are pointed out, I do not expect our administrators to go on a fishing expedition to find errors on vaguely-described or unnamed systems.
marksmith
In the time it took to complain, it us possible the issue could gave been resolved.
Database issues only effect database.
They have no impact on radio settings, or any radio operations.
PJH
I've noticed on the x36 products that if you simply update the database, all/most of the settings revert back to default. I don't recall it doing that behavior last year (I don't update mine that often unless I'm traveling, as local stuff is fairly static).
Just last night this occurred when I updated (even though many nationwide systems were avoided and/or turned off) and today when I updated a fav list.
If you read the scanner, then update and write back to it, it seems to preserve the scanner settings for nationwide and avoids.
Jay911
I update all four of my radios - 436, 536, and two HP1s - at least once a week if not more often. Sometimes I read the radios first, sometimes I don't, and the radios have never reset themselves.
If you don't read them, they will be configured however the 'profile' settings in the software is set, so if you've made changes to the radio by hand since the last time you uploaded to it, it will appear to be changed.
Ubbe
Stockholm, Sweden
I've noticed on the x36 products that if you simply update the database, all/most of the settings revert back to default..... Just last night this occurred when I updated (even though many nationwide systems were avoided and/or turned off) and today when I updated a fav list....
The database doesn't update the fav list, you have to do that yourself and if you forget to first read the scanner you will overwrite the avoid list with the one you have stored on your PC and it will be reset to a previous date.
I always read my scanner and choose not to overwrite the lists on my PC, it will then only update the profile where the avoid list sits. I discovered that the 536's avoid list are not of the DMA kind. It has a fixed value of max 250. When I search all bands I have all known frequencies avoided to catch new transmissions but 250 avoids are not enough, bummer. Maybe I need to convert to PC based search using Proscan or similar programs.
/Ubbe
