HP782 firmware update
VK6NCB
HI all,
has anybody had any issues with firmware updates on HP782 radios ?
upgrading to 2.5.08.013 and most radios upgrade correctly, though there has been a few where it would run through the first part of the upgrade a few times, restarting the computer has run the second part of the update, and though the radio shows it is running 2.5.08.013, it also shows "upgrade failed" when powered on.
I also have two radios where I cannot get them to run the second part of the upgrade, and show upgrade failed when powered on, though they accept the codeplug written for the later fimware
Im looking for any suggestions and ideas here, Im great on the install side of things, still have a lot to learn on the software side, especially with Hytera
cgservice
Try to do this: 1. Run the Upgradekit V2.5.08.013 or a higher version. 2. After Upgradekit finishes updating BL2, don"t close Upgradekit, disconnect and reconnect the battery (after reconnecting the battery the radio will boot into BL3 mode). 3. Press the Upgrade button again. If everything goes well, Upgradekit will continue the upgrade process. 4. Wait until the upgrade process is successfully completed. 5. Check that the problem is solved.
VK6NCB
That seems to work ! Thank you so much...
