HT1250 HT Programming
Project25_MASTR
TX-COMU
Texas
Professional CPS will work just fine on a Windows 7 32 or 64 BIT system. You’ve likely got a bad cable or a missing driver. If you can’t get an OEM cable, then make sure you at least have a cable with an FTDI chipset. Prolific cables sometimes will not play nice with Motorola software.
Can’t say I’ve ever gotten it working properly on 64 bit (it does work though). I don’t have to support the things anymore so I stopped trying …
bware2122
I have it working on a 64.
Sent from my ONEPLUS A6013 using Tapatalk
radioman2001
New York North Carolina and all points in between
Quote"Professional CPS will work just fine on a Windows 7 32 or 64 BIT system.
Only the latest works with 64 bit machines, I think it was 6.12 and up. Your problem is if the computer is not see the USB cable there is either a problem with the cable or you computer. If it is seeing the USB check the drivers and ports so you can select the right one when the software asks you prior to reading radio.
brndnstffrd
CT
If you are using a Toughbook, I'd recommend just getting a serial programming cable. They are cheap enough and you won't have these driver issues. There are some radios that they don't make serial cables for, but if they make one, I always choose that over a USB cable since it avoids the driver issue headaches all together.
kjl13
I was going to for this radio, but I couldn’t find one, for all my other radios I use a serial cable.
