firemedic78
I am looking for someone who is extremely familiar with programming the 1000, specifically for fire/ems anencies that use quick call II tone codes. I have found some techs but aren't familiar with the detailed programming....basically, I want my toggle mode switches as follows...
A- QCII alert mode(pager mode)
B- Channel monitor mode( Monitor the channel the radio is on)
C- Priority scan set to whatever channel my radio is on...Obviously, I usually have Ch. 1 as priority because that is our county fire channel that does the paging....but I want to be able to switch the channel, once we are on scene, to our fire tac channel and then have that be the priority channel while I am scanning...That way I can still hear our county channels incase another call comes out, but if traffic is keyed up on the tac channel that my selector knob is on, it will alert me and become the priority channel, until incident is terminated and then switch back to Ch. 1 and then that is priority channel.
Side function button settings: All I would like, is one button be the nuisance delete during scan mode( preferably the blue side button, but any of the three buttons will work), and then only other setting is one button to squelch when I push it, which in turn reset's my radio while in pager mode(Toggle A when radio is on Ch. 1, otherwise, radio will be open after tones are set off and green LED light continuously flashes until I push the squelch button to reset it to page mode) My radio model #'s end in CN & DN. I know that some model numbers wont do certain settings and functions that other model numbers will do, but I think the DN models will do exactly as I am asking. I have a friend on another volunteer fire department and a bordering County that has his radio set exactly the way I have listed here, and his model is a DN. But I also have a radio that ends with CN, and have heard that particular model will do the same functions. basically, I just need to know, when I go into the toggle mode setting on the software, which settings at the bottom do I choose. I know there are several that you can choose from, like program 1, program 2, hi/ low, lo/ hi, ect.. and then at the bottom, it shows your ABC options that each letter does foe that particular setting. I believe program one is probably what I want, it shows A is 1 open squelch, 2 is scan off, B is 1, blank, 2 scan off, C is 1, blank, 2 scan on.... f that is not the correct toggle mode to program for what I want, please tell me which toggle program selection I want to select.... and if there is a different setting I have to go to and the quick call settings to make toggle A silence while on channel 1 until Tones are alerted. I know this is a long post, but if you are the right one that is familiar with programming a volunteer fire or EMS HT-1000, then you should know what I am talking about. Shoot me a private message if you have any advice on which toggle position setting I want programmed into the radio(i.e...program 1, program 2, ect...) and the side function switch programming for the nuisance delete and the squelch. And finally, with the priority scan on, how to set the radio to have your priority channel to whatever channel you are on. thank you very much in advance.
Chris
Chris
