HT1000 Waterproof rating?
photoguy2
Does anyone know what the official IP rating for the HT1000 (and the rest of the jedis) is? I've heard all the story's from firefighters etc, and I know some of the Sabers are submersible. But I have not been able to find an official /\/\ spec.
Thnaks
FFPM571
The Mid South
No.. Jedi's are not waterproof. They are not the best at repelling water. SaberR and XTS R models are only if they have been factory or Motorola shop serviced and then properly repaired using the correct method of maintaining the seal and pressurization
photoguy2
So just rainproof at best.
Thanks, that was what I needed to know.
MTS2000des
5B2_BEE00 Czar
The HT1000 is rated for mil-spec 810C,D and E for rain, humidity and salt fog but not immersion of any kind:
http://www.repeater-builder.com/motorola/jedi/pdfs/ht1000-specs.pdf
As FFPM571 says these radios are NOT very water tight, the biggest point of entry is the speaker felt and main O-ring, especially if the radio is opened up and care not taken to prevent marring of the sealing area or O-ring itself.
Even in a hard rain the speaker itself will become saturated with water because there is no plastic membrane over it, just a thick felt pad which will only soak up so much water. When we used MTS2000s this was a common problem especially during the rainy season in the spring/summer. An RSM is a must as they at least have plastic membranes over the speaker element.
they are wonderful radios but not one to take swimming with you.
