Ht1250 Charger?
Will001
SC
I have a predicament: I just bought a Motorola HT1250 at a hamfest. It came with an Impres battery model no. HNN4002a, and 2 chargers, the first being a impres model WPLN4114AR, and the second being Motorola charger model NTN8831A. Neither charger will charge th radio, excemt the NTN8831A charger, in which I have to shove crumpled up paper in it to even charge. Also, the battery doesn't fit that good in either of the chargers. If anyone has any suggestions or comments on why this is, I would greatly appreciate it.
FFPM571
The Mid South
because they are the wrong chargers for an HT1250 What you have are for an XTS3000/5000 or HT1000
Will001
SC
Ok thanks for the reply! Does anyone know the correct charger for the HT1250?
Matakovich1
Las Vegas
You need a HKLN4226A. Can be had on Ebay for about $25. For the impress charger its going to cost you about $50 for a single charger or$325-$350 for a 6 bay one. The impress chargers are nice and condition your battery. But the impress batteries run a little more than a normal battery. I have 2 ht1250s and I have Batteries I rotate with them. Every few months I do run all my batteries thru a Motorola BMS to condition them.
Will001
SC
Would a HNN9008A charger work? I just found one on Amazon
Matakovich1
Las Vegas
The hnn9008a is a battery not a charger. AAHTN3000D Is the factory OEM charger. If you shop on amazon look up motorola ht1250 charger and look for a motorola one. Stay away from the aftermarket ones. When I just looked on amazon some are using the battery number for the charger. The only factory one I saw was $20 for a used one and $28 for a new one. Go with a new one if you can swing it. I went aftermarket once. I got 2 batteried and a charger for $75. The batteries crapped out after a year and the charger was right behind them. So after that I went motorola for everything. They last longer.
