HT1250 CPS help
ryan81986
I have been trying to program a group of HT1250s that I have. When attempting to read the radio I get the following error:
"80040154: Couldn't createinstance on the device after getting UUID"
CPS version is R06.12.02 and the models are all AAH25SDF9AA5AN.
Anyone have any idea what this might be? I've never seen this error before. I also have an older version of CPS as well but that says unsupported model. The radios state that the software version is R05.14.00.
K2NEC
5F6
If it says unsupported model it is probably a Europe, Asia, or other Non-American version of the HT1250 housed in an HT1250 housing. When you try to program one of these versions with the American version of the software it will usually give you a region error and you will need to get the CPS that corresponds with that version of radio (next to impossible). Where did you buy these radio's from?
Keep in mind I could be completely wrong and this is just my attempt at trying to help you.
cg
Connecticut
What Windows version are you using? an online search seems to suggest a Windows error. Suggestions included using XP to program.
chris
n3obl
ØAES-1056
PA
It will run on windows 7. BUT it needs to be 32 bit.
mm
oregon
I run pro cps R06.12.05 on 32 and 64 bit pc's under win 7 and win 8.1 and I have no issues with programming my ht750 low, ht1250 220 and cdm1550 uhf radios.
I use a dell tablet and a toshiba laptop.
radioman2001
New York North Carolina and all points in between
I have run into problems depending on the model of the laptop or computer. Our Panasonic Toughbooks won't do it on 64 bit but are OK on 32 bit some Dells are the same hit and miss. If you want to be sure it works use a 32 bit and XP-SP-3. Never had a problem with that combination, or use VM.
BTW we use serial ports only, no USB.
K2NEC
5F6
I have no problems with my windows 7 desktop both 64 and 32 bit.
ryan81986
For the record, this laptop is an old Dell Inspiron with a serial port. I've been using this laptop to program CDM, HT and MCS series radios for probably 8 years without much of an issue, except the odd error here and there. Usually related to needing newer CPS. But this is the first time getting this error. It's possible it's 32 bit not 64, I'll have to double check.
