HT1250 Programming
ptfd13
Columbus, Ohio
I've been programming my 1250 for years now through the software and just got a new computer. The software installed and the USB driver installed for the programming cable but when I try to "read device" it just gives me a message saying "Cannot creat unknown radio component." I'm just wondering if that means it's not recgonizing the radio or what the problem is. It also gives this message even if the radio is not connected to the computer. I've used Vista with the software for about a year with no problem so I know it's not the operating system. I would greatly appreciate any help. Thanks!
dagwag77
Boston Metro Area
Does vista recognize the com port that you're using with the USB device? Also, I'm sure you know all the tweaks with using vista and the CPS (themes you can use, etc...) ? And you're still using 32 bit Vista, not 64 bit?
ptfd13
Columbus, Ohio
No luck with the compatibility mode. I think I just might give Motorola a call tomorrow and see what they have to say. I may need to purchase a new version that will work on 64bit. Hopefully not though. Thanks for all your help. I'll post what motorola has to say.
stokes718
Lake Stevens, Wa
have gone into device manager and found out what com port it is useing and set the software to read from port. you may have to change the com port to a lower unused com port like com 1 or 2. i had some trouble the first time i used it with vista and thats what i had to do.
OhioFF
Lancaster OH
I am having a similar problem. i Have a USB ribless cable that i have used on my computer before and still do on an XP machine but is will not re-install on my Vista 32bit ultimate Dell laptop. it worked before but nothing seems to work now. the Device manage says that the cable cannot start and the CPS program ask if the computer has any com ports. if I un-install the cable the CPS can see the com ports. any help would be appreciated
hooks455
Bowie County
i had the same problem, I tried adjusting the setting on the port speed and now i am getting the message of the region is not supported by the program
MPFD535
NJ
I have 2 usb to db9 adaptors that I had laying around only 1 that I had worked with motorola radios, Never really looked into why because it worked.
