HT1250 questions
firebell9137
Hi. I have an ht1250 radio. It's almost done being programmed just needs to have a long tone (928.1) in the quik call ii decoding. Anybody know how to do that in the cps? I know how to do 2 tone. Not long tone.
And does anyone know how to hear the encoding 2 tone sets when u press the call alert and ptt button so i know when it's done?
K2NEC
5F6
It's a drop down menu option. If you are looking for just a long tone and no other tone I don't think it's possible.
As for the encode, you need to set up a side tone. I think by default it should already be set.
firebell9137
Ok thanks
n7maq-1
Oregon
It should be able to do it, just use A-B/Long B and enter 928.1 in both A and B.
Jim
K2NEC
5F6
This doesn't work. FD near me uses a steady tone and it doesn't decode if you put the tone into both.
n7maq-1
Oregon
Ok then just enter another tone in A slot. Also be sure the long tone time is set low enough to decode. It has been close to 20 years but we serviced a fire department that still used a single long tone and it worked. let me know if it doesn't work like that and I can mess around on the bench in the next few days possibly.
n7maq-1
Oregon
I just tested and I had no issues with both A and B set as 928.1 A-B/Long B
n3obl
ØAES-1056
PA
Thanks. Also the 1250 cant decode mdc1200 id aliases like 1640 is MED 4 right? Just makin sure
If you have mdc system set to decode then yes you can have alias. However you can only have a channel decode for two tone OR MDC1200. not both.
firebell9137
Really? Cool. Where can i set up the list? Right now it's only doing the 4 digit radio ids.
a417
Make sure your Signaling -> MDC system is set up correctly, and then go to CALL -> MDC Call -> make an entry for each unit you want to decode to an alias.
K2NEC
5F6
I would like to correct my previous statement. I just tried this out again and it worked for me just fine. It was probably user error when I tried it a few months back. My bad!
firebell9137
Not a problem, brought back memories of overtime looking at that CPS again.
Does anyone know what the volume section's alert tone volume offset should be set at in the alert tones/radio configuration tab? I want the quikcall ii beeps be controlled by the volume knob
K2NEC
5F6
Mine is set to -30
But also make sure "Alert tone fixed volume" isn't checked
