Could be....
bomber2782 said:
I just bought a scantenna and put it on my roof. Its about 25 ft high or so, on a 5ft mast. My question is how do I get rid of this awful hum? I ran the coax along the edge of the roof and in through an existing coax hole is the side of the house. This is the first time I have put up an antenna, so I'm a newbie. What could be causing this hum? I don;t get it with the regular antenna. What may cause the hum?
Thanks for the help.
If this is your first "outside" antenns, the hum could be simply "in the air" in your neighborhood.
We used to have a hum that pretty much destroyed ANY low band reception a few years back.
We traced it to the Gallipolis Locks and Dam on the Ohio River.....One day it simply "went away" and everything was "clear" again....
How close are you to your nearest power company transformer. If a transformer is starting to go bad, you'll hear a hum - maybe a little static too.
Now for the bad part, we have a service station on the corner from us. When their compressor runs, I get "noise" from it on my scaner!!!!
As Hoser and a couple of other posters eluded to, try a short jumper at the antenna. While you're up there, you might rotate the antenna and see if the direction changes the hum too. Maybe aime AWAY from the source!
Steve/KB8FAR
