Hytera HP Android App (Hytool)
dazey77
Anyone happen to know where to find the Android Hytool app for the HP series?
All I find on Google play is the S1 Pro app.
I do have a version of it (1.0.06.011.1) and it has an update feature. . . but that isn't working.
I understand that the current version is something in the 4.x range. Have also emailed a supplier but havent had anything back yet.
Anyone know anything? Cheers!
dazey77
Thanks but The HyRadio one seems to be the same S1pro one and not for the HPs.
I have the 1.0.06.10.1 apk but not the new one (which is referenced in this table)
Muxlow
Super Secret
Middlesex County
Thats because im 97% sure there is no app to program H series radios from a phone
dazey77
So, I have got the original version 1 installed on an old phone and I can read and write to both HP605s and HP685s. Its clunky and the update tool is still failing with a "check update failed" but at least it is sort of working with V3 radios.
ronaldod
You still have it that app ?
Muxlow
Super Secret
Middlesex County
Best to get it from your dealer.
Im a hytera dealer and have never herd of this app, isnt on the dealer portal and our hytera hq for canada has never herd of it either. So not sure this is a "ask your dealer" kinda thing
ronaldod
As far i know it is an app that connects with MDM and allows wireless/BT programming of the device HP devices. It works kinda..
Muxlow
Super Secret
Middlesex County
Just checked the MDM section and dont see anything in that section either. If you end up finding it id like to give it a go also
Only thing i DO see is phone app for the S1 series radio thats it
dazey77
It does exist and my dealer did eventually manage to get it. It direct programs things like BP565BT and HP6xxG. Not as full featured as the S1 Pro App but it works. Press PTT and side button on the radio and it enters a BT programming mode. Does seem to have a bug with read/write passwords in that the app only accepts numbers not letters.
It works kinda yes. Can blow in any config you like but there is only so much editing of a config that can be done in the app. So can swap a radio between two configs fine, or make simple amendments but not detailed settings. Hytool will take configs from the CPS. It does not require MDM.
ronaldod
the thing is i would like to be able to set the BT broadcast name to a unique identifier. like asset code.
AA7TT
You are right. it does exist. Seems Hytera is hiding a lot of things to dealers. 😅
AA7TT
Here's how it looks like
dazey77
Curious, how do you have it working with a 780, did this get added in recent firmware? In my tool the only supported 7 series is HP79Ex and my hp785G doesn’t go into BT programming mode(3.2.20.008 firmware). On all the other radios I hold ptt and a side button for 3 secs to enter BT programming mode. This doesn’t exist on the 785 and cps doesn’t have the control to enable BT programming (as it does on a HP685)
AA7TT
My HP780 is a special version (I guess?) from China that can support both PDT and DMR (NVOC and AMBE). and the firmware is quite old (2.5 something). But i believe all HP780 from China will support this App. Let me ask my friends to confirm.
ronaldod
You need to enable it in the cps first. Software control.
dazey77
I am aware of this, I have it working on HP6xx. I don't have that option in the cps for the 785 (unless Its moved somewhere odd?!). It is a 785G BTW
Its called 'Wireless Connect' on the HP685 and its In Common/Setting
Control does not exist on HP785, at least on my CPS
