Hytera MD782
W4END
Harvest
Good day - I have read a good number of posts and still needing help finding a PW for the MD782.
I have a used 782 that no matter what version of CPS I use, I am unable to reset to default or read the radio due to password protections. The only thing I can actually do is "read reset logs" from any CPS I have. It tells me that the read reset log was successful.
Currently the radio has firmware A5.00.15.001, So far I have tried CPS 2, 5, 6, 9 and even tried some Tuner software and Flashburn sortware. With those last 2 I can not read the radio. The only way I see the radio talking to the computer is when using the "read reset logs".
Options?
Thanks for the help.
a2s
Update the firmware to a higher version, for which you can find a compatible CPS version and reset the radio to default factory settings.
W4END
Harvest
Thanks for the quick reply...
I have tried V6.00.05.12.NA2 and I get the standard - "This radio data version does not match the default file"
a2s
Do you have a Telegram? PM me your contact. I'll try to help you
wcoriston
Buff.
Ulster County, New York
Use the firmware tool to upgrade to a current firmware. I believe the current version is:
DMR_TerminalBatchUpgrade_Subscribe_TO_V9.02.04.001.iM_iN
Then use the matching CPS to reset the radio to factory state.
PORTABLE_i_CPS_V9.02.12.000.iM(NA2)
Open the CPS, go to Program and set your COM port, then go back to Program and click Reset Default Data. Once completed power cycle and read the radio.
AA7TT
Out of curiosity, do you know what's the meaning of "iN" suffix?
dazey77
All v9 firmware is IN and it removed some Motorola infringing things like TDMA. I don’t recall what it stands for
headsense
Member - Learner Driver
I believe the (i) designation reflects the releases or revisions with removal of patent infringing Motorola features / techonology and (M) designated a major change in the architecture / format of the software. I thought I'd seen releases as (i) and later (iM) ?
The infringing Motorola technology features that were claimed and then validated by the courts included (they didnt win everything)
1. Fast Scan for RMO 2. Rapid Re-Key 3. Direct Mode Psuedo Trunking.
dazey77
Think you mean dual capacity direct mode (#3) . Pseudo trunking is hytera proprietary and is still in current firmware. They took out what Hytera called TDMA, which was the same as Moto DCDM
