Hytera PD982
jasej
Hidalgo Texas
Good Morning !
I have a Hytera PD982 radio, which at first glance does not turn on, but when I connect it to the computer with the programming cable and turn the power button, I hear it connecting on the computer but suddenly it tells me that it does not recognize the USB cable or the radio!
I have used this cable on this computer many times without issue, but now I have this problem with this Hytera PD982 radio.
Any ideas on what to do, would be appreciated.
Regards my friends.
cgservice
Good Morning !
Regards my friends.
The bootloader is dead. It's a bricked radio mate. JTAG will help you.
jasej
Hidalgo Texas
Thank you, my friend!
Do you have any idea how to do that using JTAG?
Thanks.
I have heard a lot about the mentioned JTAG, specifically for Hytera radios, but there is no exact or minimal information to know how to do or use that method to reset the Hytera radios. Any idea on how to do it would be very helpful if someone could comment on it.
cgservice
To reset Hytera radios? I see you don't even understand what you're talking about. Not to reset, but to restore the bootloader. There are no instructions. If you're hoping someone will post a manual on flashing via JTAG here, I think you'll have to wait a long time. You'll find the JTAG pinout in the service manual. You need to flash the bootloader into the flash memory chip. Figure out how you can do that and your problem will be solved.
jasej
Hidalgo Texas
Ok,
Yes, the correct word should have been 'restore', which is almost the same, speaking about the topic in this post... And well, I will figure out how to do this and thank you for the tip, in the search for the exact point, in the service manual of the radio in question! Thank you.
