Hytera X1p CPS Software
nodsew
Hello, I have bought a Hytera X1p, however the software CPS version doesn´t match.
The Hytera radio Data Ver: D7.06.02.005.
So, where could I get the correct CPS Software to programme the radio?
headsense
Member - Learner Driver
Oceania East Coast
I believe that CPS V8.05.06.011 NA2 is suitable and backward compatible for < V8.05.07.004 Firmwares and so should work for you ........
V7.06.05.002 was the 10th major firmware update and last before the move to Version 8.0 firmware. If your firmware version number is correct it was/has a minor interim update version. You have quoted Data Ver: and this can be different from Firmware Ver: in the radio.
Are you quoting from radio back plate under battery OR Radio > Menu > Settings > Device Info > Firmware Ver: ?
What CPS version / Sales Region version are you using but it is not working due to mismatch currently ? This version should be able to update directly to later V9.0(im) firmware / software combination if desired also.
nodsew
Thanks Sir, I have found the correct version of CPS, and works perfect.
It is V8.00.09.007.NA2
Best regards
