Hytera X1P (Full Encrypt)
cgservice
Идентификатор радио отличается.
Итак, я принимаю вызов в Hytera (та же частота, tg, cc…), однако звук отсутствует. Аналоговая частота звучит хорошо. (Мой другой Anytone принимает звук хорошо)
Я не знаю. Я расследую.
как мне получить чистый кодplug для hytera X1p? возможно какая-то конфигурация неверна и я не могу ее найти.
сбросить настройки до значений по умолчанию
Radio ID is different.
So, I receive the call in the hytera (Same frecuency, tg, cc…) however sound is mute. Analog frequency sounds good. (My other Anytone receive sound good)
I don’t know. I am investigating.
how could I get a clear codeplug for the hytera X1p? perhaps some configuration is bad and I can’t found.
reset to default settings...
aromka1
I am trying to put default, However I see this message. The serial is the same, because no problem to programming but can’t restore
cgservice
Go to Menu - Settings - Device Info and look at Radio Data Version. Write here what version
Forts
Ontario, Canada
Previous versions of CPS came with a ton of blank sample codeplugs, you could definitely get one from there.
aromka1
I think that the best option is update the firmware at the last, and use the last CPS.
It is true that my fw and cps are ok, however I think that FW could be corrupted some data, because I have some issues that don’t understand. With my other radios not problem, however this has several issues. So, how could I update safely the Fw for the last possible?
aromka1
Good News!!
I have solved my problem.
Now it works perfect in DMR and encryption.
I have updated the firmware for last version.
Maybe some files damaged or corrupted, I don’t know. The only thing is that it work perfect.
Thanks for your helpful. Now my X1p is working at 100% without any problem.
