Chaos703
Quite by chance I stumbled over a solution for an annoying feature in the Pro97 that has beguiled me for years. This problem is not addressed in the users manual so I hope I'm not about to find out that I'm the only idiot in the forum who doesn't know this.
For years I've thought the only way to put a talkgroup in hold mode is to wait for it to go active then press PSE or T. Well, I just accidentally I figured out how to do it manually:
1. While the scanner is scanning the trunked system you want to monitor, press PGM and T. This should put the scanner in program mode
2. Use your arrow keys to select the talkgroup you want to monitor
3. Press F and T.
The next thing you should see is **ID Hold mode** and your talkgroup.
Did this help anyone?
3. Press F and T.
