Baofeng Issue with programming Baofeng DM1701
kc8ppo
Yellville, Arkansas
First post. Admin if I'm putting this in the wrong section, please move it where it needs to be.
I've been out of the hobby for a number of years but recently my interested has come back. There isn't much FM activity here so I'm getting back into DMR.
I picked up a Baofeng DM-1701 to use with a hotspot. Since I use Ubuntu as my OS, I threw Windows 10 on a spare laptop. Downloaded CPS, installed the drivers, etc.
Everything connects as it should. CPS will read the codeplug from the radio with no issues. I edit it and dump it to the radio. Everything, by appearances, is working. The radio reboots, etc. Except that the new codeplug will not be saved in the radio. I go into the radio settings and nothing I changed has saved.
I'm at a loss as to what could be the problem. Stock firmware, stock CPS software. I'm going to put OpenGD77 on it but I need to get this figured out first.
Any ideas why the codeplug isn't actually writing to the radio? Is there a "read-only" setting that I need to adjust?
KJ4DHF
Did you check Program Radio under menu Item tab in CPS
kb1fua
Stover MO
I had similar issues after updating firmware.
I ended up putting OpenGD77 on it, reprogrammed everything, and it worked fine!! It's been two years now still rocking!
Edit:
Not to mention the volume works better, and annoying beep goes away!
It really makes the 1701 a whole new radio!
N4KVE
PALM BEACH, FLORIDA
The OpenGD77 turns Clark Kent into Superman. I would never have considered a CCR until I saw a friend’s 1701 with the 77 FW. He loaned me his radio, & I ended up getting one for about $60. If it croaks, I’ll just toss it.
