KE7IZL
I live in Seattle, Washington. I often here these transmissions. You can hear them every day.They often fade which suggests ionospheric distortion of the signal, which means I'm not receiving it line-of-sight, but rather on ionospheric bounce, which means the source of the signal is quite some distance away, not right here in Seattle.
I can't figure out what digital mode it is. It's not anything I can decode on MultiPSK, but it sounds very similar to Pactor-1 ARQ. I received it last night at 12:20AM Pacific Daylight Time. I checked in on the signal again today at 12:18PM Pacific Daylight Time, and it was going then too (not sure if there were any breaks in the signal between last night and this morning though). However right now at 1:35PM Pacific Daylight Time, the signal is not going (or at least it is being silenced at my location due to ionospheric effects), nor is there any other signal in its place.
It seems to be a packet based digital mode. By its packet length it is definitely closer to Pactor ARQ, not Amtor ARQ. However it lasts a bit longer than Pactor. Also it it has an ACK waiting period that's much longer than ones like Amtor or Pactor who's waiting slot is barely wide enough to fit the ACK reply in. Several such reply packets could fit into the wait period in this mode. My first thought was maybe packet radio, but HF packet is 300 baud, but this sounded slower, like Pactor-1 ARQ in 100baud mode. So I took out MultiPSK and tried to decode it with it set to Pactor, but (as expected) it didn't decode it. The packet was just too long for a standard Pactor packet.
Also it wasn't in a ham band (at least not any that's used in the US), but had a center audio frequency about 1.4kHz when my Icom PCR1000 was set to USB and tuned to 13.055MHz (putting it's center RF at 13.0564MHz, well outside any ham band, at least in the US). Thus it's likely to be for some professional communication equipment, and may not be a standard mode for ham operation. I don't know what is being sent even (text, telemetry data, etc).
Here I've posted a download link to a zip archive containing three MP3 files. One is a recording I made of the signal I am talking about, and the other 2 are Amtor ARQ and Pactor-1 ARQ (which I downloaded from a radio sounds site, and then trimmed to make a reasonable length). These 2 files are just a reference to compare to the signal I recorded.
Unknown pactor-like FSK signal.zip
And here's a zip archive containing the spectrograms of each of the 3 signals that were in the above zip archive.
Unknown pactor-like FSK signal spectrogram.zip
I just looked at this FCC frequency table http://transition.fcc.gov/oet/spectrum/table/fcctable.pdf (accurate as of June 2 of 2011) and it seems that signal is in a band that is used in the US and internationally as a "maritime mobile" band. I often find strange signals such as this in various HF maritime bands. Unlike other unusual modes on these bands which you may hear once and never again, this one is one of the more common modes, but I have no clue what it is.
From spectrograms it seems to have a frequency shift of 100Hz. From running it through this neat audio software I downloaded called Analog Box (which lets you make tons of different DSP devices modulators, filters, etc using a "flow chart" like system) I managed to find out a lot more about the signal. It is 100baud, and each packet consists of 153 bits. It also keeps repeating the EXACT same pattern of bits, like a beacon, so it's unlikely that the waiting period is actually used for an ARQ ACK/NAK reply, but rather for some kind of connection reply to the beacon hardware from another signal source trying to connect to the beacon.
If someone can tell me what this signal is, I'll be really happy, because as much as I've analyzed it and tried to figure out what it is, I can't put a name on the digital mode that's being used, or even what it's being used for. I've been hearing it now for years on my ICom PCR1000 receiver and have no clue what it is. Any help here will be very much appreciated.
