DSDPlus I have lost my “Last seen” window in Fast Lane.
radionut44
Kernersville, NC
I am running 2.448 because I get the new Windows “You cannot run this App on your PC” error when I try to run 2.457, but until today I was still getting the last seen window, but now I now longer get the window. How do I get it back? And is anyone else getting error with 2.457?
cg
Connecticut
Don't know about "last seen window" If you are talking about the Current Seen display...
Window tab, Current Seen Groups, Current Seen Radios
Are you saying the antivirus is flagging it? Microsoft Windows Security on my Windows 11 computer said the zipped file had a virus. You can tell it to run anyway and it works fine. False positive hit.
radionut44
Kernersville, NC
This is the error…not from antivirus, but from Windows when I try to run the DsdPlus exe from the new version.
Yes, I think that is the screen I no longer see. I couldn‘t give the title since I can’t see it!1704326939323.png
cg
Connecticut
When reporting a problem with Windows and software, it is always helpful to post the Windows version you are using.
Since the older version works, something changed between your computer and the new files. I would suggest deleting the new version zipped and unzipped folders. Then download the new one while watching for an antivirus hit. If it goes through OK, unzip it and check the folder to ensure there are 3 files, the DSDPlus.exe file is there and it is 629KB
slicerwizard
Toronto, Ontario
I get the new Windows “You cannot run this App on your PC” error when I try to run...
Sounds like a corrupted exe file, probably had a size of zero bytes. Likely caused by a failure to properly extract from a zip archive.
When Windows complains about a file, you should at least look at the file.
