IC-F6021 Mic Input
kf5zty
Tulsa, Ok
Hey guys, got some ideas I’m tossing around and wanting to find the best way to do this. I’ve got some recorded audio that I am trying to transmit, but I’m wanting to check to make sure the audio levels are compatible.
My Device uses line out which In think is around 1.5v (I don’t have any way to measure this). Can this be plugged into the mic port with an adapter? Or with the accessory cable? I’m not finding a lot of information when I search, just companies selling radios and icom support just refers me to a distributor.
Anyone have any guidance?
You'd need to pad the audio levels way down to mic level.
Mic level is probably somewhere around the 5mV range. Simply turning down the volume on the audio player won't be sufficient.
Impedance should be the same. The mic level inputs are usually 600Ω and audio line level outputs are usually 600Ω also.
You could use something like this to transition from line level to mic level:
You'll also need to trigger Push To Talk, but that's easy to do. Pin 7 (ground) and 4 (PTT) on the front RJ-45 microphone connector
kf5zty
Tulsa, Ok
I would go to the rear accessory connector. Thats why its there. After installing the pig tail just solder the pads required then use that to input your audio.
That is what I was aiming for, and I found this tech note on the forum, I am just worried about the audio levels matching up. I guess I really just want to be sure I don't damage the radio if they don't match.
  • zsm00123_f5020.pdf
